Activity Forums Blackmagic Design VideoHub-mix Pal/Ntsc?
  • VideoHub-mix Pal/Ntsc?
    Posted by Shane Chadder on July 2, 2005 at 9:53 pm
    Hi
    Anyone know if the VideoHub digital router will support a mix of Pal and Ntsc signals at the same time? I assume Declink can accept Pal or Ntsc also?
    Shane Chadder replied 21 years, 1 month ago 2 Members · 2 Replies
  • Luke Maslen
    July 4, 2005 at 8:06 am
    Hi Shane,
    Yes, you can be using various formats of NTSC, PAL, HDTV720 and HDTV1080 simultaneously.
    All DeckLink cards can handle NTSC and PAL and we supply easy setups or presets to make this easy in Final Cut Pro, Premiere Pro and Blackmagic Deck Control. The DeckLink HD series of cards can also switch to HDTV 720 and HDTV 1080.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Shane Chadder
    July 4, 2005 at 9:01 pm
    Sounds great. Thanks
