Activity Forums Blackmagic Design Videohub
  • Posted by Ronak Desai on August 4, 2013 at 4:25 pm
    Can anyone confirm if embedded audio in the SDI is also routed to the output or does it end up being stripped out?
    Is genlocking required? I don’t need to use it to live switch but I don’t want any issues with the video/audio being out of sync when I do route signals.
    Any general issues I should know about?
    Baz Leffler replied 13 years, 1 month ago 2 Members · 1 Reply
  • Baz Leffler
    August 4, 2013 at 11:23 pm
    full 16 channels of audio are part of the routed signal.
    Genlock has no part in A/V sync issues – its only there to provide a ‘vertical interval’ switch reference if sources are genlocked.
    Baz
