Activity Forums Adobe Premiere Pro video/audio tracks don’t move in tandem
  • video/audio tracks don’t move in tandem
    Posted by Abhishek Kumar on March 13, 2012 at 11:00 pm
    Hi all,
    So when I insert an edit into track 1 in the timeline, as I try to move the video to the upper track (2) in some instances, the audio doesn’t move to track 2; it stays on track 1.
    Anyone know why? And better yet, how this can be fixed.
    Many thanks,
    @K
    J. c. Berger replied 14 years, 3 months ago 4 Members · 5 Replies
  • Todd Kopriva
    March 15, 2012 at 12:20 am
    See this FAQ entry.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Abhishek Kumar
    March 15, 2012 at 1:14 am
    ‘Fraid you misunderstood the problem, Todd. I have stereo audio and track audio is set to stereo audio. The issue is, when I do an insert, say, at a time x:y on the timeline on track one, which is the default, but then want to move it to another track (i.e. track two) at, say, x-5:y. When I move the video to this track, that happens fine. But while the audio moves with the video the same distance horizontally, there is no track change. It resides on top of the intended audio — like an overwrite, but without the overwrite.
  • Alan Peil
    March 15, 2012 at 5:13 pm
    The way I’ve dealt with this since CS2 is to manually move the audio down to the track I want. The only way I know that works.
  • Abhishek Kumar
    March 15, 2012 at 5:28 pm
    That’s what I’ve had to do to fix the issue as well. It’s just inconvenient…and shouldn’t have to be 4.5 updates later. (I’m using CS5.5.)
  • J. c. Berger
    June 19, 2012 at 6:23 pm
    Any updates on this?
