Activity Forums Adobe Premiere Pro Video/Audio delay when editing in PAL
  • Video/Audio delay when editing in PAL
    Posted by Csaanv on October 10, 2006 at 7:29 pm
    When I edit in a NTSC project my desktop audio/video matches the output of my DV deck (via Firewire) which goes to a monitor and sound board. However when I setup a PAL project and start editing I get a 1-2 second delay between my desktop video to my video monitor and speakers. I have tried this using a DSR-25 and the newer HVR-M25U, same results. Using the exact same DV output setups in Final Cut Pro I don’t get the delay. Is this normal for APP2?
    Craig Howard replied 19 years, 11 months ago 3 Members · 5 Replies
  • Vince Becquiot
    October 10, 2006 at 8:44 pm
    I don;t edit in PAL, but you could try setting your audio out to firewire and take the audio out of the deck instead and see if that issue is still there.
    Vince
  • Csaanv
    October 11, 2006 at 1:54 pm
    Thanks for your suggestion and I understand what you are saying but my issue is when editing in PAL the audio and video from the DV deck is lagging about 1 second behind the audio and video coming from the desktop. This does not happen when I edit in NTSC or when I edit in Final Cut Pro in PAL.
  • Craig Howard
    October 12, 2006 at 4:36 am
    What file version of msdv.sys are you using ?
    Windows/System32/ Drivers
    Craig Howard
    Shooter Film Company
    Auckland
    New Zealand
    Premiere Pro 2.0
  • Csaanv
    October 12, 2006 at 2:22 pm
    Hi Craig, It is version 5.3.3790.1830
  • Craig Howard
    October 12, 2006 at 7:44 pm
    The version I am using is 5.1.2600.0
    Note that my issue is similar to yours only in the delay between internal and external monitors, but I did not have the complication of the NTSC thing oir FCP,so I have no idea if it is even a fix for you.
    BTW: I am a PAL Lander.
    Craig Howard
    Auckland
    New Zealand
    Premiere Pro 2.0
