Activity Forums Apple Final Cut Pro Legacy Video won’t playback after unknown key hit
  • Video won’t playback after unknown key hit
    Posted by Ignatius Gorin on December 2, 2009 at 8:41 am
    Hi, I was adding subtitles to a project yesterday night very late, and I inadvertently hit some key, really don’t know which one, or a combination, that ended up disabling video playback somehow. Meaning that the canevas stays black, whatever I do, while sound is playing, and I still can see clips or sub if I double click on it. Sound is playing fine. If I copy/paste the timeline into a new sequence or project, it’s the same.
    Any idea? Thanks.
    Ignatius Gorin replied 16 years, 9 months ago 2 Members · 3 Replies
  • Ignatius Gorin
    December 2, 2009 at 8:43 am
    PS: I’m using 5.1.4 on a Macpro and 10.4.11
    Edit: It does the same with all (previous) projects I open now.
  • Tamas Erdosi
    December 2, 2009 at 9:41 am
    I think you switched your canvas from image mode to wireframe.In the canvas window at the top there are 3 buttons.Use the right one and set it back to “Image” as well as set the left one to “Fit to window”.
    If the problem still exists it should be something deeper than just a simple setting question, I think.
    If so try to trash the preferences.
    https://www.tamaserdosi.eu
    Tamas Erdosi / http://www.tamaserdosi.eu
  • Ignatius Gorin
    December 2, 2009 at 10:09 am
    THANK YOU!
    Duh…
    — Ig.
