Activity Forums Adobe Premiere Pro Video won’t play after render
  • Video won’t play after render
    Posted by Kevin Peters on May 17, 2018 at 12:55 am
    I have been working on a short film which I have rendered out many multiple times before without any problems but now all of a sudden when I render my sequence the file will not play in quicktime or vlc. The file doesn’t have a thumbnail like they did before which is the tail tail sign it’s not going to play.
    Nothing in the way of new/changed clips would be the cause so it’s really weird.
    I tried to create a new sequence and copied the clips into it but still no luck. If I render out half of the time line and then the other half it works fine so i’m baffled.
    Render settings
    h.264
    1920×800
    vbr, 2 pass
    14 / 16
    render at max depth checked
    would love some help
    Mike Jones replied 8 years, 4 months ago 2 Members · 1 Reply
  • Mike Jones
    May 17, 2018 at 12:51 pm
    Kevin,
    Are you trying to render or export?
    A few things to try in trouble shooting if you are trying to export:
    Did you try exporting 3/4 or your video?
    Did you try exporting all but the last frame?
    Did you try exporting to another codec?
