Activity › Forums › Adobe After Effects › Video with plenty of drops
  • Video with plenty of drops
    Posted by Juan Manuel on February 15, 2013 at 5:19 pm
    Hi guys, I have a TV show recorded on minidv which was recorded with plenty of drops (defective camera perhaps?) and too little B-Roll to cover up for them. I’m attaching an example.
    The way I’m thinking regarding those frames with issues which simply can’t be cut or covered with another shot is some fancy rotoscoping or cloning images from the previous frames.
    However, that’s too much time consuming and I’m also having a hard time getting good results.
    Is there another way to try to fix this?
    Juan Manuel replied 13 years, 7 months ago 2 Members · 2 Replies
  • John Cuevas
    February 15, 2013 at 5:31 pm
    You can try pt_FrameRestorer. I haven’t tried it from damaged frames, but it did a good job for me when I had to restore missing frames from a 3D render someone supplied me.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Juan Manuel
    February 15, 2013 at 5:52 pm
    THANKS! Just did a small test and it worked pretty well!
