Mark Greenwood
February 12, 2013 at 9:37 amOk there is now a new version for Vegas Pro 12
https://www.mgreenwood.com.au/upload/videowall/tictactoe.dll
Save this and then insert it into your ScriptMenu folder – under where you have vegas installed (typcially
c:\program files\sony\vegas pro 12.0\Script Menu)Then restart (or start) Vegas and then find the Script under Tools/Scripting/TicTacToe.
Wolfgang Wally
February 12, 2013 at 12:11 pmHi Mark! Thanks for the promptly work – i will test it tomorrow when i will be back! Many thanks from Austria!
Wolfgang Wally
February 13, 2013 at 7:16 pmHi Mark, i’m again!
I tested and i’ll be happy! It’s already ok for me – thanks again!
Jaysri Sridharan
March 13, 2013 at 12:19 pmHi Mark,
Thanks for your work. When I tried the link for vegas pro 11, I get an error message as file not found. Any clue as to what happened? can you give me an idea how to install -
Jaysri Sridharan
March 13, 2013 at 12:49 pmHI Paul,
I get the same message even though I have installed the 2dll. version as instructed by Mark.How you resolved this issue? Can you guide me? Thanks in advance -
Jaysri Sridharan
March 13, 2013 at 12:53 pmHi Mark ,
I get the same message even though I have installed the 2dll. version as instructed by you to Paul.I have rescanned and restarted too.Still I get the same message. Can you guide me? Thanks in advance -
Mark Greenwood
March 13, 2013 at 9:52 pmI’ll have to check this evening – it’s probably the new version is built against version 12 and hence won’t work in 11.
I’ll see if I still have the version 11 DLL files and build a version for 11 and a version for 12
Paul Beller
May 7, 2013 at 11:38 amI came back to tictactoe.dll and it works perfectly now on my SV10. Thank you very much Mark!!!
I think it is a great script. I don’t know how to use it so far, but i will learn:)
