Activity Forums Adobe After Effects Video wall content expression?
  • Video wall content expression?
    Posted by Mark Grossardt on January 5, 2009 at 10:09 pm
    Hi all,
    I haven’t figured out how to do this yet, so I’m hoping one of you has the brains to help me out.
    I want to create a simple video wall (10 screens x 20 screens), but I want each screen in the wall to be looping content from a single shared video layer starting at random times. Essentially, I’m looking for an expression that says “the video looping in this layer will be taken from video layer x at a time chosen at random.”
    Is this possible using expressions? Or is there a better way to accomplish this effect without using the brute force method of dropping video into 200 different comps?
    Thanks in advance for your responses.
    Mark Grossardt replied 17 years, 8 months ago 2 Members · 2 Replies
  • David Bogie
    January 6, 2009 at 3:55 pm
    In Motion, we’d use a simple replicator, set it to spit out its children in a grid, and assign the source video to random start frames.
    In AE, I might use a particle system like Foam. It has the ability to use a random start frame from the particle source. But, of course, Foam’s particles cannot be herded into a nice grid.
    ;’m not only AE machine at the moment but I think you can search the online help system for something like “random frame” and you should get a list of effects that offer the feature.
    visit some of these AE Expressions forums and help sites and search for video wall and random frame:
    https://www.aenhancers.com/
    https://www.motionscript.com/mastering-expressions/simulation-basics-3.html
    https://www.motionscript.com/mastering-expressions/table-of-contents.html
    https://www.nabscripts.com/Downloads/downloads_en_1.php?id=7
    https://aeioweyou.blogspot.com/
    Hope you get better advice over the next few days.
    BTW: There’s nothing “simple” about a 200 unit video wall!
    bogiesan
  • Mark Grossardt
    January 6, 2009 at 6:08 pm
    Thanks for your response and advice, bogiesan.
    I actually think I’ve stumbled onto a decent AE solution. I’m using Trapcode Particular to create a grid emitter set up to my dimensions, then choosing a custom particle that points to a comp containing the video files and choose Random – Play loop. I just set a keyframe at frame one to emit 200 particles, then 0 particles at frame two, set the lifespan of the particles as long as I need it and bang, “simple” 200 unit video wall (kinda).
    Thanks again, and I’ll check out those threads you linked. You never know when you’ll find a better way to do something.
