Activity Forums Adobe Premiere Pro Video Wall aspect ratio?
  • Video Wall aspect ratio?
    Posted by Dave Felder on February 14, 2013 at 7:07 pm
    A client has asked me to produce a video that will be shown a Sony Ziris multiple monitor display.
    The delivery format spec is 1920 x 1080, which is no big deal for us. However, in the fine print, the RFP suggest using Vector graphics because their resolution is 11300 x 4400. Doing a little math, that’s an aspect ratio of about 2.5, while the 1980 x 1020 is 1.77.
    Has anyone ever produced materials for a Ziris system? It doesn’t make sense to me to produce at 1.77 if it’s being displayed at 2.5, although I would assume that the exhibition company knows what it’s asking for. Sounds like either black bars on the side or stretched images, right?
    Dave Felder replied 13 years, 6 months ago 2 Members · 2 Replies
  • Angelo Lorenzo
    February 14, 2013 at 7:27 pm
    Why don’t you have your client put you in touch with the technician who will be running the display?
    The Ziris system is simply a management and delivery architecture which means the delivery specs can vary greatly from implementation to implementation.
    The 11300×4400 sounds like the resolution of the entire wall which means the RFP is, hopefully, suggesting some kind of placeholder image if needed. That would be my speculation.
    Angelo Lorenzo
    Need to encode ProRes on your Windows PC?
    Introducing ProRes Helper, an awesome little app that makes it possible
    Fallen Empire Digital Production Services – Los Angeles
    RED transcoding, on-set DIT, and RED Epic rental services
    Fallen Empire – The Blog
    A blog dedicated to filmmaking, the RED workflow, and DIT tips and tricks
  • Dave Felder
    February 18, 2013 at 2:14 pm
    Thanks for the reply Angelo. I have reached out to the convention center, I just thought someone here might have some experience to share so I can discuss it being a little better informed.
    Regards,
    Dave
