Activity Forums Adobe Premiere Pro Video Usage and Audio Usage incorrect
  • Video Usage and Audio Usage incorrect
    Posted by Wes Plate on August 11, 2006 at 10:01 pm
    I have a largish project in 1.5 that I’m reducing, I’ve removed all but one sequence and the one sequence only contains a few clips, however many clips in the bin still say they are used in a sequence.
    When I try to delete the clips from the project I’m warned they’re in use.
    Anyone know if this is fixable?
    — Wes Plate
    Automatic Duck
    Wes Plate replied 20 years, 1 month ago 3 Members · 5 Replies
  • Troy Murison
    August 11, 2006 at 10:40 pm
    Hey Wes,
    Have you tried restarting PPro? Maybe that will force a refresh of the
    project window? Don’t have any other ideas… I’ll try to do a test
    with a large 1.5 project later…
    Hope your summer is going well!
    -Troy Murison
    Seattle, WA
  • Wes Plate
    August 11, 2006 at 10:56 pm
    Yes, PPro has been restarted. Thanks for trying. 🙂
    — Wes Plate
    Automatic Duck
  • Troy Murison
    August 12, 2006 at 12:35 am
    Wes,
    I just tried this in PPro 2.0 and the usage updates properly.
    I realized however that I don’t have 1.5 installed here any more
    so I’ll have to wait ’til I get home to test that.
    -Troy.
  • Baz Leffler
    August 12, 2006 at 1:12 am
    Hey Wes
    In the project window click on one of those ‘phantom’ clips and then up at the top of the project window (where the clip thumbnail appears) there is a little arrow. Click on that and it will display the sequence that it is in and then you can click on that and it will open that sequence at that clip.
    My bet is that you still have some sequences that you haven’t deleted from the project window but only from the timeline window
    Baz
  • Wes Plate
    August 17, 2006 at 8:22 pm
    Thanks for your reply. I checked, and this particular project has only one sequence, and one of the clips that says it is used has no little menu like you describe. Probably just a bug.
    — Wes Plate
    Automatic Duck
