Activity Forums Avid Media Composer Video Underrun errors?
  • Video Underrun errors?
    Posted by Bluewingoliver on September 20, 2006 at 3:32 pm
    I had two errors while playing out a longer sequence of about 20 minutes today after digitizing from a DVD. The first error, about 10 minutes in, would happen everytime I tried to play through that particular point, be it the source clip or the sequence. I redigitized that section, match framed it by eye, and played it out again, only to have a second error about five minutes later. I was able to play the sequence again without the error re-occuring, so I just did an insert edit a few frames before the problem.
    Did I inadvertently do something to cause these errors? Is there an easier way to correct the errors, or prevent them from occuring again? It caused a decent amount of lost time that I got annoyed about.
    Thank in advance!
    Scott Simmons replied 19 years, 11 months ago 2 Members · 1 Reply
  • Scott Simmons
    September 25, 2006 at 2:05 pm
    Where is the media living? Is it on a dedicated fast drive? Is this Dv25 or a format that require high data rates…. sounds like the drive isn’t fast enough.
    Life is linear. Edit life.
