Activity Forums Adobe Encore DVD Video Transitions in Menus
  • Video Transitions in Menus
    Posted by Sebastian Fidler on June 2, 2005 at 1:48 am
    I’m trying to build a menu in Encore
    that uses video transitions to move
    between different menus. How does this
    work?
    I’ve seen multiple DVDs that use this
    effect. If anyone is familiar with it,
    EyeballNYC’s Vol. 4 reel does it
    exceptionally well.
    I attempted to make such a transition
    using 2 menus and a transition video clip
    from After Effects, but there was a
    3 or so second black gap between each
    menu that ruined the effect.
    Another, unrelated question: If i have
    a DVD I like is there a way to see how
    it was created like you can with the
    “view source” command in web pages? It
    would be a great way to learn new tricks.
    I’d appreciate the help.
    Sebastian Fidler replied 21 years, 3 months ago 2 Members · 3 Replies
  • Dave Friend
    June 2, 2005 at 4:04 pm
    [Sebastian Fidler] “there was a
    menu that ruined the effect.”
    Were you previewing within Encore when you saw this black gap?
    If so, what you are seeing is Encore’s preview function loading the next playback cell. The previewer switches to black while this cue-up is happening. With a DVD player the usual behavior is to freeze the last frame shown while the disc is cued to the next cell. Therefore, with an actual disc in a player you would not see the black. Also, with a disc the response time will probably be quicker.
    Otherwise it sounds like the workflow you are using to get the effect you describe is correct.
    Dave
  • Sebastian Fidler
    June 2, 2005 at 5:55 pm
    That’s good news. Hopefully that is
    the issue. I will try it tonight
    when I get home from work. Thanks.
  • Sebastian Fidler
    June 3, 2005 at 1:09 am
    That did it! Thanks, it makes the
    menu flow much more smoothly.
