Activity Forums Adobe Encore DVD Video Transition Discrepancy
  • Video Transition Discrepancy
    Posted by Justin Skotarczyk on April 11, 2008 at 12:26 am
    I am trying to make an apparently seamless transition from menu to menu, but having issues with the video transition appearing larger than the interactive menu.
    The menu is a .psd file 720×480 and the video is a .mov with the same dimensions.
    The effect I am going for is when you click the button it animates, shifting to a different position by the next menu screen. Every aspect of the background should stay the same otherwise.
    Even upon burning a DVD, there is a jarring increase in frame dimension when the transition occurs.
    Any suggestions?
    Justin Skotarczyk replied 18 years, 5 months ago 1 Member · 1 Reply
  • Justin Skotarczyk
    April 13, 2008 at 12:32 am
    I figured out the issue. Encore tends to squish menus down to 720×480 regardless of the fact that it’ll accept 720×486 and 720×540 compositions as menus.
    We ran a few tests to confirm this, and ended up rebuilding our menus in Photoshop using a 720×480 template, and used that file to reanimate in After Effects. After doing this we were able to get near seamless video transitions in Encore.
    Justin Skotarczyk
    DI Film
    justins@milagropost.com
    Milagro Post
    Detroit, MI
    Freelance VFX Artist
    skoproduction@yahoo.com
