Activity › Forums › VEGAS Pro › Video track not loading on project load
  • Video track not loading on project load
    Posted by Kawaii Tenshi on April 7, 2012 at 1:26 pm
    Hello,
    Since Sony vegas 7 and now 11
    i’m having the issue that whenever I reload a project at least one of the video track is not loaded…
    to fix this I have to open the videos in that track in trimmer an play it fully to get them working in the original video track…
    when I get media info on the files in those tracks I have
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : High@L3.1
    Format settings, CABAC : Yes
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 2mn 25s
    Bit rate : 1 544 Kbps
    Maximum bit rate : 4 427 Kbps
    Width : 1 280 pixels
    Height : 720 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Variable
    Frame rate : 23.976 fps
    Minimum frame rate : 17.241 fps
    Maximum frame rate : 24.390 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.070
    Stream size : 26.8 MiB (91%)
    anyone a solution for this: as it can be annoying to let a video source play every single time just to edit like 1 sec of it
    Kawaii Tenshi replied 14 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
