Activity Forums Adobe Premiere Pro Video to Still Simple task not working
  • Video to Still Simple task not working
    Posted by David Andrews on April 20, 2010 at 12:42 pm
    We are just getting CS4 and I am confused regarding how to do a simple task. I simply want to freeze the last frame of video so I can fade it out. When I look it up under the help it tells me to go to file and export to frame and that is what I used to do however in CS4 there is no export to frame. When I go to clips and try this it does it once than does some kind of funky drop frame after it plays back fine. Any ideas other then going to AE to do this.
    Tracy Peterson replied 16 years, 5 months ago 2 Members · 1 Reply
  • Tracy Peterson
    April 22, 2010 at 5:44 pm
    Cut it on the frame you want to freeze. Then copy the clip, right click it and “hold frame” on the second clip on the frame as well. Then move the second clip to after the cut then extend it as long as you need it.
    CS4 removed the “export frame” option and it was returned after much griping to CS5.
    Tracy Peterson
    http://www.onetwomany.com
