Activity Forums Apple Final Cut Pro Legacy Video to Flash
  • Walter Biscardi
    July 4, 2008 at 12:17 pm
    There were several very long threads about Flash in the past three weeks. Use the Search Function to find them. Search Flash, SWF, and FLV
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    Read my Blog!
    View Walter Biscardi's profile on LinkedIn
  • David Scott
    July 4, 2008 at 2:17 pm
    thanks Walter
    David Scott,
    Senior Editor,
    GOD TV (UK)
  • David Scott
    July 5, 2008 at 5:05 pm
    Hi Walter
    I checked out the suggested threads, but no-one seems to be talking about a hardware solution?
    Has anyone heard of any hardware out there that can convert a video signal to a flash file in realtime? I’ve got 100’s of hours to convert and when I tested it using Compressor it was a 10:1 ratio – that’s a lot of time! There must be an equivalent to a PAL to NTSC standards convertor out there?
    All suggestions gratefully received!
    David Scott,
    Senior Editor,
    GOD TV (UK)
  • David Bogie
    July 7, 2008 at 4:31 pm
    Flash is a big nut. If your source material is dense, you are dong heavy compression and, yes, it takes a while, two passes are required to maintain the best image quality.
    Sorry I don’t have any better advice for you. We do smaller stuff from DV, not a big deal for us. Probably best solution is to purchase an Adobe encoder product.
    bogiesan
  • David Scott
    July 7, 2008 at 9:22 pm
    Thanks for your comment. I’ve found someone who can build me a hardware encoder for £8000 that’s currently under consideration, but it is a bit pricey!
    Cheers
    David Scott,
    Senior Editor,
    GOD TV (UK)
