Video Strobing Problem from AE Export
I’m using Adobe After Effects 7.0 Professional
I just used keylight for chroma keying a person shot on a green screen. The footage was shot on DV with a frame rate of 29.97.
I captured the footage in Final Cut Pro. I edited all the good takes of the host in front of the green screen. Then, I exported the clips from Final Cut and import them into AE. I used Keylight to key the green out, and I export the keyed footage as lossless with alpha with a 29.97 frame rate. However, when I imported the keyed footage into final cut, the footage is kind of strobing like a film rate or something.
It is kind of cool, but I don’t want that look. I want the original frame rate look. By the way, my comp settings were set to DV settings. 720 X 480 and a frame rate of 29.97
Can anyone please help me with my problem?
Also, can anyone give the me the proper settings for a AE export so I won’t have to render the file in final cut?
Thanks.
Mark
