Activity Forums Apple Final Cut Pro Legacy Video Stretched – bars on sides – I’ve tried everything
  • Video Stretched – bars on sides – I’ve tried everything
    Posted by Joey Gorina on June 2, 2010 at 2:06 pm
    Hello.
    I am using Final Cut Pro 6.
    The raw footage from my HMC40 is 1280×720 and these open up great in QT correctly and there are no bars anywhere – the info on “get info” just says 1280×720.
    After editing in FCP, Sequence settings are the following:
    1280×720
    Pixel aspect- NTSC DV 720×480 – ANAMORPHIC IS CHECKED!
    Compressor h.264
    The “canvas” in FCP seems to fit it correctly – except it has bars on the left and right – but the aspect of the video looks fine.
    When exporting – for example using “quicktime conversion” – format- quicktime movie – the dimensions (current) in the settings box automatically hits 470×198 as compressor native. Huh?
    Doing all the changes to make it match my sequence – NTSC 720×480, the video is exported into a stretched vertically video and a “box” shape video with giant bars on the left and right.
    Could someone please help me? I’ve spent weeks on this video and I can’t figure this out – I have about 12 different exports using different settings and they ALL have the bars on the sides with stretched vertically video 🙁
    I am begging for help here.
    Joey
    Nick Price replied 15 years, 11 months ago 4 Members · 4 Replies
  • Joey Gorina
    June 2, 2010 at 4:13 pm
  • David Roth weiss
    June 2, 2010 at 4:31 pm
    Anamorphic should never be checked when working in HD. That setting is for SD widescreen only. You’ve graduated now, so keep this in mind permanently.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Rafael Amador
    June 3, 2010 at 1:05 am
    [Joey Gorina] “1280×720
    Pixel aspect- NTSC DV 720×480 – ANAMORPHIC IS CHECKED! Compressor h.264 “
    1280 x 720 is ALWAYS Square pixels and NEVER Anamorphic.
    Your sequence pixels are NTSC and the sequence Anamorphic.
    Change that.
    rafael
    http://www.nagavideo.com
  • Nick Price
    June 3, 2010 at 2:16 pm
    HI joey,
    to save confusion, if i am unsure about the correct sequence settings, i create a new blank sequence(shift+n) and then drag a clip into it. It will ask ask you if you want to change your sequence settings to match the clip and voila, you should get a timeline with correct aspect ratio and codec applied.
    You can then change you current sequences to match.
    You will also know that you have something wrong if you have a green line above your clip on the timeline. No green line and you have the settings correct. ANy shade of green (or red/orange) and the clip settings dont match the sequence settings and you need to render (unless it plays realtime)
    cheers
    nick
