Activity Forums Blackmagic Design Video storage for WinXP – DecklinkSP
  • Video storage for WinXP – DecklinkSP
    Posted by Testrun666 on July 5, 2006 at 7:58 pm
    Please don’t flame me if this was a recent discussion point — I just found this forum. 🙂
    I’m looking to build out a dual AMD box (Tyan motherboard). I’m looking to keep costs down.
    Any one have a good recommendation for internal SATA drives/controller that comfortably supports 8bit SD video?
    Thanks! TR
    Sarcoma replied 20 years, 2 months ago 4 Members · 5 Replies
  • Bob Zelin
    July 6, 2006 at 1:50 am
    the cheapest thing that will work well is a 2 port Firmtek SATA card in a 2 port Firmtek external enclosure, with 2 SATA drives (Hitachi, Seagate, Western Digital) – the size your choice. This will do 8 and 10 bit SDI and DVCProHD, no problems. Make sure you stripe the 2 drives together RAID 0 with Apple Disk Utility. 1 Terabyte will be under $1000, and of course, if you need less storage, it will cost less (the 250 Gig drives are pretty cheap these days).
    Don’t cheap out with internal drives – the externals cause no heat issues, and let you swap out drives with no aggrivation. Everything is hot swap, like Firewire 800.
    Bob Zelin
  • Alan Okey
    July 6, 2006 at 3:54 pm
    [Bob Zelin] “Make sure you stripe the 2 drives together RAID 0 with Apple Disk Utility.”
    In WinXP? I gotta see this…
  • Sarcoma
    July 6, 2006 at 5:06 pm
    If the board you’re getting has ide & sata onboard (ie tyan2895)then four big drives striped on the four sata channels would be ok for 8bit SD…
    …otherwise have a look at the Highpoint Rocketraid cards.
    Cheers, Andy
  • Testrun666
    July 7, 2006 at 2:20 am
    Thanks so much for the response!
    You read my mind Andy — I’m currently looking at getting the following —
  • Sarcoma
    July 7, 2006 at 12:55 pm
    8 x 500 drives will be enough to give you HD as well…maybe even as a raid5 set.
    Andy
