Activity Forums Apple Final Cut Pro Legacy video stalling and skipping a everything else that can go wrong !
  • video stalling and skipping a everything else that can go wrong !
    Posted by Arty Gold on July 28, 2005 at 3:05 pm
    putting a video together for a danc studio…
    it’s over two hours long…
    i put it all together,,,and everytime i go to make a print to tape…
    it either starts skipping…or the audio will stop dead in it’s tracks…
    so i did an audio mixdown…the audio slipped…towards the end…
    the video is the only thing on a 200 gb harddrive…7200rpm…8mb cache–maxtor…
    i’ve never had any problems with this drive or any of my drives (knock on wood)
    i have the option of going firewire 400 or 800 and i’ve tried both…it’s doing exactly the same thing…
    any solutions other than starting all over from the beginning ?
    i’m having a hard time doing that or at least coming to grips with that.
    any help would be very very very much appreciated.
    by the way it tends to happen in all different places..
    is there any way to test the integrity of the video that was captured ? is it possible that the video is not secure in any way ?
    Kevin Downer replied 21 years, 1 month ago 6 Members · 7 Replies
  • 7 Replies
  • Arty Gold
    July 28, 2005 at 3:08 pm
    sorry…
    also i’m using
    a g-5 dual 1.8 with 3 gigs or ram
  • Jonathan Miller
    July 28, 2005 at 7:33 pm
    Frustrating, isn’t it! You’ve put all this work into producing the thing, and it’s just how you want it. Now, you can’t get the thing output and therefore can’t deliver it. Uuuugggghhhh!
    Alright, have you tried making the entire piece into a self-contained movie, and then printing to tape from that single movie?
    A lot of times that will solve your problem.
    Good luck!
    Jon
    TreeLine Productions
    Fort Collins, CO USA
  • Walter Biscardi
    July 28, 2005 at 7:38 pm
    Maxtor is not a drive I recommend to anyone who is doing serious video work, that is, you’re earning your livlihood from your work. LaCie, G-Tech and WiebeTech are all good firewire drives for A/V work.
    A lot of dropped frames comes from two things: drive speed and media management. Drive speed depends on the connection, how fragmented a drive is and the drive itself. On the Media Management side, if you have your media spread out too much on the drive, then that can cause dropped frames. I’ve seen people create multiple folders for media from a single project on a drive and FCP can drop frames.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • John
    July 28, 2005 at 10:53 pm
    Hi Walter – so, if I have a lot of media for a project, and I have a lot of different folders for that media for organizational purposes – (even though all the media resides on 1 drive), I will get dropped frames?
  • Steve Courtney
    July 28, 2005 at 11:32 pm
    I was having the same problem at one time, and was tearing my hair out trying to figure it out. Then I realized my scratch-disk had been inadvertently set to my main hardrive, the same one that was running the FCP app. D’oh. All my renders were trying to play off the main internal hard-drive. No wonder I was getting playback errors.
    Also, you might check on the locations of any stills you might be working with. A lot of times people drag jpegs or picts or whatever onto their desktop, and FCP has to access the main hard-drive to get to the media, while also trying to run real-time video. That can be an invitation to Dropped-Frame City.
    Good luck,
    Steve
    FCTV
  • Steve Courtney
    July 28, 2005 at 11:55 pm
    [Walter Biscardi] “Maxtor is not a drive I recommend to anyone who is doing serious video work, that is, you’re earning your livlihood from your work. LaCie, G-Tech and WiebeTech are all good firewire drives for A/V work.”
    Any specific models you’d recommend, Walter? I still need to buy a replacement drive or two, and don’t want to waste any more money. I was leaning toward the LaCie BigDisk Extreme 500GB. Is that a good use of my resources, or should I get a 160GB and wait for prices to go down?
    Steve
  • Kevin Downer
    July 29, 2005 at 1:19 pm
    Walter, not to pick but just to clarify your previous statement one of your selected manufacturers:
    Lacie is just providing a metal housing for the drive. It’s not a drive manufacturer.
    Lacie in many cases uses Maxtor drives in their cases. I just had my older FW Lacie die on me recently. After opening it, it uses a Maxtor DiamondMax Plus 9. Take one apart sometime. The only shock absorbing thing in the case is a little crappy foam strip. That nice vent hole in the back? There is no fan in it so it’s useless and purely cosmetic…like the rest of it. Probably why it runs so quietly though. 😉
    You might think about going SATA external or internal as it seems to becoming the next best thing to SCSI for its price point and will help with the hiccups.
    If you need to stay FW, I would suggest grabbing a Mercury Elite Pro enclosure and then get the drive of your choice to stick in it.
    I learned my lesson from my recent HD crash.
