Activity Forums VEGAS Pro Video Stabilizer not working Vegas Pro 20
  • Video Stabilizer not working Vegas Pro 20
    Posted by Dave Giardina on May 2, 2024 at 10:35 pm
    Hi Everyone – I’m having an issue with the Video Stabilizer plugin on Vegas Pro 20. I go to the plugin, choose “professional” then click “analyze” but then nothing happens. It stays at 0 no matter how short the event is. What am I missing? Thanks for your help.
    Dave Giardina replied 2 years, 4 months ago 2 Members · 2 Replies
  • Hector Vera
    May 6, 2024 at 7:19 pm
    That is pretty odd, I had only used Video Stabilizer once when working on a client’s project a few months back. Sometimes the tool is not perfect. But in your case if nothing is working at all, maybe try uninstalling the plugin and reinstalling. Also try restarting your OS afterwards to see if the results are different. If that does not work, you may need to look for a better plugin file that works cause sometimes, some plugins does not work properly as it should. I hope it helps.
  • Dave Giardina
    May 7, 2024 at 4:47 pm
    Thanks for these suggestions. I’ll try them out and see!
