Activity Forums Apple Final Cut Pro Legacy Video Speeds Up After Introducing After Effects Title…HELP!
  • Video Speeds Up After Introducing After Effects Title…HELP!
    Posted by Ry Tullis on February 28, 2010 at 3:33 pm
    Hey people,
    I constantly have this problem when I introduce an Adobe AE composition to my edit. Everything will be fine at first, but then I will open my project and lo’ and behold certain sections of my edit will play in fast forward and then the screen will appear black.
    I have absolutely no idea why this is happening or how to fix it. I have tried changing Playback Settings but to no avail.
    Does anyone have any clues?
    Thanks very much
    -JT
    Dan Flaherty replied 16 years, 5 months ago 3 Members · 3 Replies
  • David Johnson
    February 28, 2010 at 5:35 pm
    Sounds like mixed frame rates are confusing FCP … are your AE renders at the same frame rate as your FCP sequences and footage?
  • Ry Tullis
    March 1, 2010 at 8:05 pm
    Dave and David,
    Thank you for your input.
    Maybe this info will shed some light on the subject. Here are my sequence settings and clip info.
    SEQUENCE SETTINGS:
    Frame Size: 1440 x 1080
    Pixel Aspect Ratio: HD 1440×1080
    Field Dominance: Upper (odd)
    Editing Time Base: 29.97
    QUICKTIME VIDEO SETTINGS
    Compressor: XDCAM EX 1080p24(35Mb/s VBR)
    CLIPS INFO
    Most of them are 1920 x 1080 @ 23.98 fps w/ Compressor XDCAM EX 1080p24…
    The others are 1440 x 1080 @ 29.97 fps w/ Compressor HDV 1080i60…
    The AE titles I created are 1920 x 1080 @ 29.97 fps w/ Compressor “Animation”
    Also, the Pixel Aspect Ratios vary from Square (1920) to HD 1440×1080
    The strange thing about it is sometimes it plays normally and sometimes it freaks out and I hvae to revert to a saved FCP file to get it back to normal…
    How does one avoid these problems when working with footage shot w/ different formats etc.?
    Thanks again for your input.
    Much appreciated.
    JT
  • Dan Flaherty
    April 20, 2010 at 4:55 am
    Hey man. I have had this happen to. Mine happens after I render my sequence. Video speeds up to exactly 150%. You need to go under the sequence tab, and go to settings. In there there is a section under render control for frame rate. Make sure that this is at 100%!!!!
    I have had this problem for almost a year now and just figured out the solution tonight. This helped me, sounds like your problem may be a tid bit different but I think this may work.
