Activity › Forums › Broadcasting › Video spec’s…
  • Video spec’s…
    Posted by Sam Lesante jr. on September 3, 2009 at 1:12 pm
    I don’t know if anyone is using this product, if so maybe you can help me.
    I bought a unit from Western Digital called WD TV HD. It is suppose to read any usb hard drive and play hd video onto an hd monitor.
    https://support.wdc.com/product/download.asp?groupid=1001&sid=112&lang=en
    I am using Final Cut Pro 6.0.6, i imported 2 hd files that i shot on my canon vixia hfs100 (they came in as 29.97 1920×1080 appleProRes422)
    when i export the 20 sec clip as an .mov using the h.264 codec with 48khz aac audio, with 30fps at 1920X1080 (as the site suggests), it plays back in a studdered way.
    I have tried to export right from FCP as a quicktime and then using ffmpeg, i have tried exporting as a quicktime conversion and i tried to export from compressor.
    Western Digital has software that converts any video to the desired codec but it is only for Windows. I have posted this question on the WD site and even asked a tech support guy but came up short.
    Anyone have any experience with this unit?
    TIA
    Sam Lesante jr. replied 17 years ago 2 Members · 2 Replies
  • Baz Leffler
    September 4, 2009 at 12:22 am
    I have this unit and HD always studders using memory stick. It plays fine off a hard drive. It obviously can read the data much faster
    Baz
    What would I do without the ‘UNDO’ button!!!!
  • Sam Lesante jr.
    September 8, 2009 at 3:16 pm
    Hey Baz,
    I am playing it off a 500gb Western Digital hard drive.
    What spec’s do you use? What do you use to compress your video to the players qualifications?
