Activity Forums Media 100 video shears and tears
  • video shears and tears
    Posted by Ernie Geefay on September 25, 2006 at 10:34 pm
    I’ve been having a problem with exports from After Effects to Media 100
    Anytime there is quick movement in the rendered video…someone running by or a quick head turn the video looks like it is tearing or shearing…rather than a nice smooth movement.
    Anyone had this problem?
    Floh Peters replied 20 years ago 4 Members · 3 Replies
  • Jim Calahan
    September 26, 2006 at 3:05 am
    Is the video widescreen? It could be a size issue.
    Jim Calahan
    KVIE, Sacramento
  • Curious Turtle
    September 26, 2006 at 5:46 am
    As Jim said, it’s likely a size issue but also make sure you’ve rendered back to the correct Media 100 codec (NTSC/PAL, square/720).
    You should check too that you’ve rendered with the correct field order.
    HTH
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
  • Floh Peters
    September 26, 2006 at 6:07 am
    [egeefay] “I’ve been having a problem with exports from After Effects to Media 100
    Anyone had this problem?”
    Are you seeing this tearing on an interlaced monitor/CRT? Or on a TFT/Plasma? Are you seeing it in AE or Media 100? Are your clips field order interpreted correctly in AE (usually done automatically)? What is your comp size in AE (PAL 720*576 or NTSC 720*486, or something else)? Which codec are you rendering into?
