Activity › Forums › VEGAS Pro › Video Rendering
  • Video Rendering
    Posted by Tim Roberts on July 7, 2010 at 6:14 pm
    New to sony vegas and need rendering help
    I think I have a bad codec or something going on. My renders have slowed to a crawl. A 1 minute test render takes 12 minutes to render. Importing video as avi and need to find quicker renders for now. Can’t afford new computer yet, but need about a 3- 1 render time for dvds for clients.
    I am using sony vegas 7d. I have a single processor pentium (yes I know its slow, but it used to render 3 minutes per minute of video). I formatted main hard drive, 250 meg. Putting windows xppro on 95gig partition, 140 gig for programs. Have a terrabyte hd for storage. Do I need different codecs.
    video stats from prefs.
    dynamic ram 383 out of 1024
    4 rendering threads
    its slow on all projects, but I use a 1 minute with two video and two audio lines.
    attributes: 720x480x24, 00:13:01:23
    format:DV
    field format lower field first
    pixel aspect 0.9091
    alpha channel none.
    frame rate 29.970
    full resolution rendering: best
    blur:gaussian
    de-interlace: none
    made an mgpeg 2 save w audio
    How do you check the codec on the input avi video?
    John Rofrano replied 16 years, 2 months ago 2 Members · 1 Reply
  • John Rofrano
    July 7, 2010 at 8:14 pm
    I see two immediate problems with your project properties:
    de-interlace: none
    If your field format is interlaced you should not have your deinterlace set to none. It should be set to Blend Fields which is the default unless there is a compelling reason to set it to Interpolate Fields.
    This is guaranteed to slow down rendering and is only needed if you are resizing high resolution stills and are having quality problems. The default setting of “Good” is more than adequate for DV video work.
    Right-click on the video event on the timeline and select Properties | Media tab then look at the Video format.
    Based on the incorrect changes to the default properties in Vegas, you may have changed something that is causing this problem without knowing it. I would recommend reseting Vegas. To do this, start Vegas by holding down the SHIFT key while you double-click on the icon. This will reset all of your preferences and make Vegas the same as the first day you installed it. You will loose any customization you have done to the preferences but you may also loose your problem so it might be worth a try.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
