Activity › Forums › Apple Final Cut Pro Legacy › Video Render files are being saved on internal drive. Why?
  • Video Render files are being saved on internal drive. Why?
    Posted by Vic Noseworthy on October 29, 2013 at 8:40 pm
    Hi, folks.
    I have been editing using an external drive, but didn’t realize the render files are going onto my internal drive. I checked the System Settings, and it says the Video Capture, Video Render, and Audio Render files should be going onto the external drive. But, when I look at the external drive, the render files aren’t there. I noticed my internal hard drive filling up, and checked. For some reason, there’s a Render folder directly on my internal drive, and that’s where the render files are going. And, as I mentioned, the System Settings indicate they will be saved on the external drive.
    Any idea why this is happening? And, what I might do to correct it?
    Thanks very much for your expertise!
    Sincerely,
    Vic
    FYI: I’m using a MacBook Pro (2008) and FCP7
    Vic Noseworthy replied 12 years, 9 months ago 3 Members · 10 Replies
  • 10 Replies
  • Vic Noseworthy
    October 29, 2013 at 11:40 pm
    Thanks, Dave. Actually, I am relatively new to FCP7, and haven’t really “tweaked” the settings much at all. It’s pretty much as it is when I purchased it.
    So, then, are you saying I can simply trash the Preferences and that will take care of it?
    Would you be kind enough to outline how I go about trashing the Preferences?
    Thanks so much for your help!
    Vic
  • Vic Noseworthy
    October 30, 2013 at 12:14 am
    Thanks very much, Dave. I will definitely check it out.
  • Vic Noseworthy
    October 30, 2013 at 5:24 am
    Hi, again, Dave. I went to the site. There are many apps. Do you happen to know the name of the one for resetting the Preferences?
    Vic
  • Jon Chappell
    October 30, 2013 at 3:04 pm
    It’s Preference Manager:
    https://www.digitalrebellion.com/prefman
    My software:
    Pro Maintenance Tools – Tools to keep Final Cut Studio, Final Cut Pro X, Avid Media Composer and Adobe Premiere Pro running smoothly and fix problems when they arise
    Pro Media Tools – Edit QuickTime chapters and metdata, detect gamma shifts, edit markers, watch renders and more
    More tools…
  • Rainer Wirth
    October 30, 2013 at 10:19 pm
    The digital rebellion stuff is very good with FCP,
    worth every cent,
    cheers
    Rainer
    factstory
    Rainer Wirth
    phone_0049-177-2156086
    Mac pro 8core
    Adobe,FCP,Avid
    several raid systems
  • Vic Noseworthy
    October 30, 2013 at 10:28 pm
    Thank you very much, Jon. I looked on the site and it says that Preference Manager requires OS 10.6 (Snow Leopard)
    However, I am using OS 10.5.8 (Leopard)
    Do you know if it will work with my OS? Or, alternatively, is there an older version that will work with OS 10.5.8?
    Thanks very much for your help.
    Vic
  • Jon Chappell
    October 30, 2013 at 11:53 pm
    Hi Vic,
    If you look at the sidebar on the right of the page I linked to you’ll find older versions for OS X 10.4 and 10.5.
    My software:
    More tools…
  • Vic Noseworthy
    October 31, 2013 at 3:22 pm
    Hey, Thank You so much, Jon. You’re very helpful!
    I hope I can figure out how to use it! :^)
    I will check it out this afternoon and hopefully get my Render files going to the proper drive.
    Again, I so appreciate your help!
  • Vic Noseworthy
    December 8, 2013 at 7:23 pm
    Hi, Jon.
    Just wanted to follow up. I did as instructed, and the problem is solved! My render files now are stored on the external drive, where they should be. Honestly, you guys are awesome! I don’t know what I’d do without knowledgeable people like you to help out!
    Thanks so very much!
    Vic
  • Vic Noseworthy
    December 8, 2013 at 7:26 pm
    Hi, Dave:
    Just wanted to say thank so much for your help! I downloaded the app and now my render files are being stored on the external drive, as they should be. Problem solved.
    You’re awesome!
    Vic
