Activity › Forums › Adobe After Effects › video reference
  • video reference
    Posted by Marcus Levin on February 15, 2011 at 12:42 pm
    Hi Creative Cow! I am Marcus from Brasil.
    I am making a short film in which there will be necessity for rodoscoping.
    I tried to capture some footage from you tube using a freeware to record activity on the computer screen. The quality I’ve got wasn’t good, which is a problem when some figure in movement is far away. Also, whenever I try to play the file generated from this freeware in after effects, the play back shows frames overlapping and gaps between them. I think that is due to the file quality as well.
    Is there only this way to record video referece (I NOT RECORDING MYSELF, BUT ANIMALS).
    I had the idea of recording the monitor using a external device. If this idea is a good alternative, which kind of camera would you recommend ? Should I use a digital photo or camcorder?
    Regards.
    Marcus Levin replied 15 years, 7 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    February 15, 2011 at 4:09 pm
    Why don’t you contact the people who posted those clips and ask them if you can get a copy of the footage they posted. Without their permission you should not use it anyway.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Joey Burnham
    February 15, 2011 at 6:11 pm
    Google “Keepvid” and use Safari as your browser.
    -Joey
  • Marcus Levin
    February 17, 2011 at 6:17 pm
    Thanks for the advice and tip.
    Regards!
