Activity › Forums › Apple Final Cut Pro Legacy › Video quality playback when using layers
  • Video quality playback when using layers
    Posted by Joe Stachler on October 20, 2005 at 10:28 pm
    I’ve recently comepleted a full software upgrade. I’ve noticed in playback, both in the FCP canvas and out to a monitor via Blackmagic, that when I am using layers such as a .mov element from LiveType, there is a noticeable difference in quality on the underlying picture (image track 1) between when other image tracks are playing at the same time and when it is by itself. It reminds me of the old optical printer transitions you’d see in films where the image quality changes on a shot from before the transition to when it starts.
    I will say that when I nest the sequence, I don’t notice it. So I may have already found my solution. But I bring it up here because I don’t want any surprises when I do my final print to video.
    Here’s my specs:
    OS X 10.4
    FCP 5.0.1
    Dual 1.42 GHz G4
    -Joe
    Joe Stachler replied 20 years, 11 months ago 2 Members · 2 Replies
  • Bret Williams
    October 21, 2005 at 2:19 am
    You mean between something that’s rendered and something that isn’t? That’s normal. What’s it look like when it’s rendered? What are your real time render settings? They’ve changed enormously since 4.x.
  • Joe Stachler
    October 25, 2005 at 12:12 am
    It’s noticeable after rendering. Settings are full quality/100%. I’m editing photo JPEG from Betacam SP source video.
    However, Iike I said, it is NOT noticeable if I nest the sequence. Not sure what’s up.
