Activity › Forums › Live Events & Streaming › Video projection with multiple audio tracks
  • Video projection with multiple audio tracks
    Posted by Philip James on January 3, 2019 at 5:27 pm
    I am going to be projecting a 42 min HD video file from my MacBook Pro at a live performance. I want to play out 8 separate audio tracks, ideally as part of the video file. I’ll output those audio tracks as 4 separate pairs. I’ll then be performing live parts along with this.
    I am wondering what the best way forward might be for this. I have VLC, Quicktime and Resolume, although I am not sure how well any of them will work with multiple audio tracks and routing separate outs. I also want the picture quality and playback stability to be as high as possible.
    Any advice would be gratefully received.
    Philip James replied 7 years, 8 months ago 2 Members · 2 Replies
  • Vince Becquiot
    January 3, 2019 at 10:16 pm
    You should be able to send out multiple channels of audio from pretty much any playback software. This will be handled by the OSX audio hardware settings.
    You should look into a USB I/O interface like MOTU https://motu.com/products
    As for the software itself, Resolume is way overkill for just simple playback, by if you own it, why not.
    Otherwise, Playback Pro, QLab, Mitti or Millumin. Whatever you chose, get a backup 🙂
    Vince Becquiot
    Indigo Live | Kaptis Media
    San Francisco Bay Area
  • Philip James
    January 4, 2019 at 9:03 am
    Thanks Vince
    I didn’t realise that these video playback options could all work with multiple audio tracks. I already have a MOTU 8M for audio output so I’m covered on that side. I guess the big question is whether I run the audio from a DAW and sync it via SMPTE to my video file or whether I run a multitrack video file and route the tracks to different outputs.
