Activity Forums Adobe After Effects Video Preview in Windows XP 64bit
  • Video Preview in Windows XP 64bit
    Posted by Guy Thompson on June 9, 2009 at 10:35 pm
    I have noticed a problem in Windows XP 64bit, I cannot select an external DVI monitor as the video preview output device in After Effects. This happens in AE7 and AECS4.
    I have contacted Adobe, but cannot get an answer via email.
    We installing a BlackMagic Intensity HDMI card as a work-around.
    We have many workstations here and none of them which have Windows XP 64 can output to a secondary DVI or VGA monitor. All have NVidia Quadro cards.
    Has anyone managed to get this to work, or has a work-around?
    Robert Morris replied 16 years, 12 months ago 3 Members · 2 Replies
  • Todd Kopriva
    June 9, 2009 at 11:37 pm
    64-bit Windows XP is not a supported operating system for After Effects.
    I don’t know that that has anything to do with your problem, but it may present difficulties. Just FYI.
    Here are the After Effects CS4 system requirements.
    You said that you contacted Adobe. How? Did you use the contact options on this page?
    (And, no, I’m not in Adobe Technical Support.)
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
  • Robert Morris
    September 26, 2009 at 10:16 pm
    I’m having the exact same problem. I have an Nvidia Quadro FX 370 card and Windows XP 64-bit. I’ve recently upgraded to CS4 and can no longer use Firewire out to a camcorder VTR and then piped from there out to my Sony monitor. VERY frustrating. I’ve used this exact setup before with no problems using XP 32-bit, and AE 6.5. Why isn’t XP 64-bit supported by Adobe CS4? Shouldn’t they know that most professionals are using 64-bit systems now? And obviously we’d like to continue using Adobe software.
    @Guy Thompson, did you resolve your problem? If I have to install an extra card for video previews, I may do that to relieve my stress while trying to finish up this job. Any info on what card I could use for a S-Video output to my Sony monitor would be very helpful! But it should be compatible with After Effects’ video preview, of course. Firewire doesn’t seem to be an option now with XP 64-bit.
    @Todd Kopriva, would you know what card to recommend for using video preview in AE to go out S-Video to a Sony monitor? Even if you can’t recommend one for XP 64-bit because it’s not supported by CS4, maybe you could suggest something that would work in XP 32-bit to give me a direction.
    Thanks.
    Fine Art Drawings | Photography | Compositing | VFX | Titles | Keying | 3D
