Activity Forums Apple Final Cut Pro Legacy video plays too fast; information already transferred
  • video plays too fast; information already transferred
    Posted by Jamie Adams on June 9, 2011 at 1:34 pm
    Another issue, how would I correct the problem with footage that has already been log and transferred? The P2 cards have been reformatted and used. Again, 720p 30fps, 1/60th on the shutter.
    Thanks in advance
    Ben Holmes replied 15 years, 2 months ago 5 Members · 12 Replies
  • 12 Replies
  • Steve Eisen
    June 9, 2011 at 1:45 pm
    Do you have audio on your footage? If yes, you undercranked your footage.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Jamie Adams
    June 9, 2011 at 1:57 pm
    Yes I have audio. Please offer me a solution. 🙂 Thanks
  • Jeremy Garchow
    June 9, 2011 at 2:01 pm
    Correct what problem?
  • Jamie Adams
    June 9, 2011 at 2:18 pm
    When I play it in the timeline the audio is out of sync. It starts out fine but then gets out of sync. Please help.
  • Jeremy Garchow
    June 9, 2011 at 2:31 pm
    We are going to need way more info about your system, settings, timeline, etc.
  • Ben Holmes
    June 9, 2011 at 2:40 pm
    Jamie – if you keep posting the same things multiple times on these forums, you’ll run out of friends.
    Try to be more precise, and give as much info as you can – clearly you don’t know yet which bits of it will be important, so include it all.
    Edit Out Ltd
    FCP Editor/Trainer/System Consultant
    EVS/VT Supervisor for live broadcast
    RED camera transfer/post
    Independent Director/Producer
    https://www.blackmagic-design.com/community/communitydetails/?UserStoryId=8757
  • Jamie Adams
    June 9, 2011 at 2:58 pm
    Sorry for any confusion; first timer posting. The info; HVX200, P2 card, Frame size 960x 720, video rate 29.97fps, shutter 1/60th, compressor DVCPROHD720p60, Data rate 7.2mb/sec., Audio rate 48.0KHz, audio 16 bit.
    I hope this is adequate. Thanks again and sorry for the mess.
  • Ben Holmes
    June 9, 2011 at 3:22 pm
    It sounds as though you are confusing ‘shutter’ with frame rate. Shutter speed has nothing to do with framerate. You’ve recorded 720p30, not 720p60 by the sounds of it.
    As David says, read both your other threads.
    Edit Out Ltd
  • Jamie Adams
    June 9, 2011 at 3:36 pm
    I had the rate at 720p, and I cannot re-transfer it; the cards have been reformatted.
    Thank you for your advice.
  • Shane Ross
    June 9, 2011 at 4:51 pm
    What? The cards have been reformatted? Dude…bad bad bad. That’s like capturing tape, and erasing the tape. KEEP THAT STUFF. You backup the P2 contents to hard drives at least. Because when stuff like this happens, and it will, as you know, you can always go back to the originals and reimport. Without them…well, you have a mess to deal with.
    For future reference, watch this tutorial. It covers the ENTIRE workflow of backing up tapeless media, to importing it into FCP. Tapeless Workflow for FCP 7 Tutorial
    Already imported…sped up…out of sync…originals gone. That’s a mess. Wish I had the time, and footage that was messed up in the same way, to help out.
    Shane
