Activity Forums Adobe Premiere Pro Video plays pixilated on HDTV. Please help.
  • Video plays pixilated on HDTV. Please help.
    Posted by Mary Davis on January 10, 2009 at 10:01 pm
    I use the XH-A1, Premier Pro and Encore to create DVDs. The footage looks fine while editing in PP and when playing back on the computer or a standard definition television. I recently got a 23″ HD TV (thanks Santa) and when I played one of my DVDs (expecting to see more of the HD experience), I was extremely disappointed in the quality. The video plays extremely pixilated. I am sure it is operator error and if anyone could offer guidance on where I have gone wrong I would truly appreciate it. I have been through other posts and not seen my actual issue.
    I have recorded footage on XH-A1 with the following settings:
    Signal Std – HD
    Frame Rate – 60i
    Comp Out – 1080i/480i
    I have captured footage in Premier Pro with the following settings:
    DV-NTSC Widescreen 48Hz 29.97 frames/second
    Pixel Aspect Ratio – D1/DV NTSC Widescreen 16:9
    Fields – Lower Field First
    Display Format – 30 fps Drop-frame timecode
    Capture Format – DV Capture
    I export to Encore with the following settings:
    Format – MPEG2-DVD
    Present – NTSC Widescreen Medium Quality
    Basic Video Settings
    Quality – 3
    TV Standard – NTSC
    Frame Rate – 29.97
    Field Order – Lower
    Pixel Aspect Ratio – Widescreen 16:9
    Bitrate Settings
    Bitrate Encoding – VBR, 1 Pass
    Minimum/Target/Maximum Bitrate – 1.5/4/7
    I appreciate your taking the time to read the above and look forward to any messages that may help me correct my problem.
    Thanks.
    Mary
    Peter Berthet replied 17 years, 7 months ago 2 Members · 1 Reply
  • Peter Berthet
    January 12, 2009 at 7:10 am
    thats pretty normal to see on an HDTV
    when youve transcoded your video in encore it downscales it to standard def
    which looks fine on a normal SD telly,
    also considering youve selected medium quality, its not going to upscale and still present well on an HDTV
    considering SD is 720×576 and a 1080i HD TV generally upscales to 1920×1080, your gonna end up with a fairly pixelated image.
    it is possible on most TVs to choose your resolution when watching a SD DVD, but when you do that it generally doesnt fill the whole frame, leaving a smaller picture in the centre of the screen surrounded by a lot of black
    ~Peter Berthet
    Sydney, Australia
