Activity › Forums › Maxon Cinema 4D › Video plays choppy
  • Video plays choppy
    Posted by Jasic Shain on November 21, 2009 at 6:34 pm
    hello
    I have some problems with cinema 4d. when i render animation at 30 fps, saved to image sequence when the animation plays it’s playing choppy edges apear jerky not smoother no matter which codec i use but if i raise the frame rate to 60 it plays smooth but the animation appears playing too quick what should i do to make it appear smooth.here are samples first one 30 FPS https://www.downloadtaxi.com/d/1258827757
    second one 60 FPS
    https://www.downloadtaxi.com/d/1258828250
    that’s my problem please some one help me come around this problem it’s really time consuming to render at 60 fps or should i stick to render at 60 fps. at what frame rate professional animations are rendered at can any one guide me?
    Jasic Shain replied 16 years, 10 months ago 4 Members · 5 Replies
  • Dominik Gut
    November 23, 2009 at 10:57 am
    Hey Jasic,
    well to me both videos seem to be identically, with no chopping edges. I had a similar problem once, but it had nothing to do with frame-rates (25fps is standard for PAL, 30fps for NTSC systems, if you don’t want to add slow-motion effects afterwards. then you should perhaps use a multiple framerate of your standard).
    Well, back to the choppy edges problem: The Quicktime player sometimes changes the representation of the movie to low quality. But only you will see it and on other Computers it looks perfectly nice, or the other way around…
    In Quicktime Player, choose “Window” and “Show Movie Properties” (Ctrl-J). In the opening window, select the Video Track, and under “Visual Settings”, “High Quality” should be checked.
    Sometimes this is the only “problem” (the quality of visualisation).
    Try. Hope it helps!
    Kind regards, Dominik.
    http://www.phirstfilm.com
    Phirstfilm Productions GmbH
    film and animation for business solutions
    Zurich, Switzerland
  • Jasic Shain
    November 23, 2009 at 1:01 pm
    no one willing to help. 🙁
  • Brian Jones
    November 23, 2009 at 2:55 pm
    What are your Antialiasing settings set at?
  • Adam Trachtenberg
    November 23, 2009 at 3:58 pm
    The edges look perfectly smooth here. As Dominick said, it’s probably an issue with your hardware/software rather than the video file.
  • Jasic Shain
    November 26, 2009 at 12:46 pm
    thanx for responding my settings are set as best filter set to animation min/max level 1×1 4×4 mip scale 50%.i am playing all clips on media player dont have quicktime installed so thats not the problem i have rendered different animations on other softwares like maya 3dmax but all apear same jerky.. changed my video card too but not solved
