Activity › Forums › Media 100 › Video plays back dark when imported from SW to Media100i
  • Video plays back dark when imported from SW to Media100i
    Posted by Henry Blood on November 28, 2006 at 6:00 pm
    Before I started using Media100SW on a G5 Quad I could export video as Media 100 NTSC-720 and it would playback fine in Media 100i but now exports are about 25% too dark but look fine while editing. I digitized the video in Media 100i. Also where ever I haven’t inserted a black clip on the clean timeline, I get a Blue background. I tried using the Media 100i compressor in Media 100SW but I get the same result -too dark. Tried exporting bars from SW installed on the G4 (different copy of SW 10.2.1) Media 100i compressor. result:same blue background and dark video through Media 100i.
    Is this a Media 100i card issue?
    G5 Quad QT 7.1.2 Media 100SW 10.2.1
    G4 Dual 500 QT 6.5.1 Media 100i/xr 8.2.3 (a?) Copyright 1993-2006 Boris FX Inc. SW 10.2.1
    HB
    Henry Blood replied 19 years, 9 months ago 2 Members · 6 Replies
  • Floh Peters
    November 28, 2006 at 6:27 pm
    How do you export? As “Self Contained”? Or as a QuickTime file with Media 100 i codec? There was an issue with video levels when using the QuickTime export in 10.1.x and 10.2.x; you should upgrade to V11.5 of Media 100 sw/Producer and try the export again. Anyway, when exporting as Self contained you should see no color and luma shift regardingless of which version you use.
  • Henry Blood
    November 28, 2006 at 7:35 pm
    “How do you export? As “Self Contained”? Or as a QuickTime file with Media 100 i codec?
    I export as a quicktime file with the media 100i codec.
    I bet Producer is the answer…maybe it handles “color range” better ;->
    Thanks once again Floh
    HB
  • Floh Peters
    November 28, 2006 at 7:37 pm
    Export as “Self Contained” (assuming that you have everything in the Media 100 i codec). This should give better quality (no recompression), it should be faster and it should not change the color/levels.
  • Henry Blood
    November 28, 2006 at 10:05 pm
    “Export as “Self Contained” (assuming that you have everything in the Media 100 i codec). This should give better quality (no recompression), it should be faster and it should not change the color/levels.”
    OK but the import into Media 100i takes more than an hour…
  • Floh Peters
    November 28, 2006 at 10:08 pm
    [hbvideo] “OK but the import into Media 100i takes more than an hour…”
    You should avoid “gaps” in your timeline. As far as I know this “slow import” into Media 100 i only happens if the timeline you are exporting contains empty areas, which are exported in a clever way to save space, but they mean a slow import for Media 100 i systems. If you have spaces in your timeline where you need black, do yourself a favor and take a black Pict, import it into Media 100 and place it there. Maybe using a “black clip” created in Media 100 does work also, but I have to admit that I did not try it.
    Floh
  • Henry Blood
    November 28, 2006 at 10:59 pm
    OK, I went ahead and got Producer and happily and thankfully its color range adjustment made the exports via Quicktime show up properly and only take 4 minutes to import. Using the media 100 HD uncompressed gave good quality too. Thanks for the tips Floh!
    HB
