Activity › Forums › Apple Final Cut Pro Legacy › video plays at 4x – audio plays fine
  • video plays at 4x – audio plays fine
    Posted by Steve Stokes on January 26, 2010 at 7:32 pm
    I am trying to edit a clip. It plays fine in quicktime, but when I put it in final cut the video plays 4 to 10x faster than the audio. What is going on here? All my other videos from this project worked fine in FCP.
    Todd Reid replied 16 years, 8 months ago 3 Members · 3 Replies
  • Steve Stokes
    January 26, 2010 at 7:35 pm
    I altered the speed on the video to %40 and it matched the audio. This is a strange problem. Does anyone have any clues?
  • Alex Elkins
    January 27, 2010 at 3:28 pm
    Hi Steve,
    1. What format was this shot?
    2. What format is the Quicktime file?
    3. What are your sequence settings? (framerate, codec etc)
    4. Does it play correctly when you double open it in the FCP viewer, as opposed to the timeline?
    If you answer those questions you should find the problem as it sounds like there’s a settings mismatch somewhere along the process.
    All the best,
    Alex
    Salad Daze Films – Freshly Tossed
    Read my blog!
  • Todd Reid
    January 27, 2010 at 4:47 pm
    did you import from P2?
    if so, go to preference and check “remove duplicate frames”, re import, and see if that helps.
    Todd Reid
    Senior Editor
    Digitized Media, Inc.
