Activity Forums Adobe Premiere Pro Video playing 4:3 when it should be playing Widescreen HD 1440 x 1080i? XML
  • Video playing 4:3 when it should be playing Widescreen HD 1440 x 1080i? XML
    Posted by Adam Berch on March 26, 2013 at 4:22 pm
    I have completed a project (a wedding) in FCP 7 that is 2 and a half hours Long.
    It was shot and edited at 1440 X 1080i HDV
    I want to bring it into a Premiere Pro CS 6 Timeline so I can use Media Encoder to encode it at High Definition. I then plan to make a Blu-Ray DVD out of it in Encore CS 6.
    Here’s what I have done:
    ) IN FCP 7 and Exported the project as an XML
    ) I then closed FCP and opened Premiere Pro CS 6
    ) I went to File —– Import and imported my XML file into Premiere Pro CS 6.
    ) The project imported in Premiere Pro CS 6 Fine (except it had to replace some transitions with crossfades)
    ) I Double Clicked on the Timeline in the Premiere Pro Project Panel and the FCP Project opened up in a Premiere Pro Timeline
    ) It all looked good except for some of the video
    ) Some of the Videos are playing in the Program Window as 4:3. The Sequence is set at 1440 x 1080i.
    ) Most of the Videos are playing as normal (Widescreen)
    I tried rendering the ones that are playing in 4:3 mode, but it does not fix the problem.
    How can I get the clips that are playing in 4:3 mode to play like they are supposed to play in Widescreen 1440 x 1080i?
    Just a reminder that the Job is already on the timeline?
    Thanks in advance
    Premiere Pro CS 6
    FCP 7
    Power Mac Intel
    Shane Ross replied 13 years, 6 months ago 3 Members · 2 Replies
