Activity Forums Apple Final Cut Pro Legacy video playbak with JAGGED EDGES
  • video playbak with JAGGED EDGES
    Posted by Mahesh Dood on June 21, 2010 at 11:39 am
    hi
    i have taken a prores file (1920x1080i 60)and put it in compressor to converted to HDV with the same same parameters. when i play the HDV file the edges look jagged, especially when the picture is moving. dont know why.
    the prores file does not have this problem. what should i do to avoid this problem
    mahesh
    Brian Miller replied 16 years, 3 months ago 4 Members · 4 Replies
  • Bouke Vahl
    June 21, 2010 at 11:52 am
    You can’t have the same params.
    HDV is 1440 instead of 1920…
    Perhaps something goes wrong there?
    Bouke
    https://www.videotoolshed.com/
    smart tools for video pros
  • Mahesh Dood
    June 21, 2010 at 12:55 pm
    hi
    my prores file is 1920x1080i 60i, i want keep the same parameters and convert in compressor to HD. i dont see any HD, but HDV which is 1440×1080. so what do i do
  • Kris Merkel
    June 21, 2010 at 3:09 pm
    What you are seeing is the interlacing in quicktime. What is your final deliverable? Answering that question will let us help point you to a compression codec. HDV is not a codec that you use to deliver a master.
    Kris Merkel
    Quad G5
    OS X 10.4.11
    FCStudio
    CalDigit Raid
  • Brian Miller
    June 21, 2010 at 7:08 pm
    also be sure to check on a broadcast monitor, you could be seeing some interlacing relating to your computer monitor vs. broadcast…
