Lliam Evans
November 11, 2009 at 1:06 amSo what the template should say is: Field Order: Upper Field First – Deinterlace Method: Blend Fields?
BTW, thanks for all the help. I really appreciate it
John Rofrano
November 12, 2009 at 2:56 am> So what the template should say is: Field Order: Upper Field First – Deinterlace Method: Blend Fields?
Yes. HD is upper filed first and DV is lower field first. Blend fields is the default deinterlace method because it retains the most temporal resolution. If, however, you have a lot of motion, you might want to try Interpolate fields but it sacrifices resolution in favor or better motion.
~jr
http://www.johnrofrano.com
http://www.vasst.com
