Activity Forums Adobe Premiere Pro Video Playback through HDMI out.
  • Shane Ross
    November 26, 2011 at 11:48 pm
    You need to use a sequence settings that corresponds with your capture cards, and your footage. For example, AJA 1080p24. Or a Matrox or Decklink setting.
    Shane
    Little Frog Post
  • Greg Burke
    November 27, 2011 at 12:15 am
    I’m using A Black-magic Intensity Pro Card
    I wear many hats.
    http://www.gregburkepost.com
  • Daniel Startek
    November 27, 2011 at 12:29 am
    Connect a DVI to HDMI cable on the second output of your video card (I use a GTX 570). With the sequence selected, go to Sequence settings/Playback settings/External device and select the 2nd monitor. Works great on my system.
  • Shane Ross
    November 27, 2011 at 3:58 am
    Then you use a black magic sequence setting, and switch the video player to Adobe player. Sounds odd, but it is what you do.
    Shane
    Little Frog Post
