Activity Forums Apple Final Cut Pro Legacy Video playback options missing
  • Video playback options missing
    Posted by Paul Redgrove on November 15, 2008 at 10:56 am
    Howdy
    Wonderfully infuriating new problem on my MacBook Pro. Wanting to playback using the Cinema Display option but when I go to View>Video Playback> I get an option of none. Is this a FCP problem or more a problem with the operating system settings?
    I’m also getting a number of apps crashing when first opened. When re-opened work fine…
    Cheers
    Paul
    Paul Redgrove replied 17 years, 9 months ago 2 Members · 4 Replies
  • Walter Biscardi
    November 15, 2008 at 1:32 pm
    [Paul Redgrove] “Wanting to playback using the Cinema Display option but when I go to View>Video Playback> I get an option of none. Is this a FCP problem or more a problem with the operating system settings? “
    How is the Cinema display attached?
    On the Crashing issue, have you run all the Software Updates? You generally have to run that about 4 or 5 times to get everything as some updates are reliant upon components being installed before they run.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
  • Paul Redgrove
    November 15, 2008 at 1:53 pm
    I was referring to playback using the full screen on the laptop. I’ve got some dodgy clips and want to be able to see some drop out. It was always a default option.
    The crashing is things like Firefox, System Preferences, QT, iTunes a real odd array not really covered by updates…although I will run some again.
    Paul Redgrove
  • Walter Biscardi
    November 16, 2008 at 1:31 pm
    [Paul Redgrove] “I was referring to playback using the full screen on the laptop. I’ve got some dodgy clips and want to be able to see some drop out. It was always a default option. “
    That Cinema Display option as I understand it is for a second monitor, I don’t believe you can use that option on a single display setup. I never use it so I’m not 100% certain.
    As for the crashing, don’t know what to tell you on those, just be sure you’re fully up to date. I’ve been running a MacBook Pro 15″ for over a year now and it’s very solid. I never use it for editing, just all my office work, email and internet.
    Read my Blog!
  • Paul Redgrove
    November 16, 2008 at 2:55 pm
    It was there. As i say it’s not a bad option to view playback nice and big when working off the laptop on OB’s etc. Maybe it’ll turn up when i re-install FCP and updates.
    I’ve been using this 17″ for a good year and its just recently that the crashing occurs. Always restart and works fine it’s just that initial start up…
    cheers
    Paul
    Paul Redgrove
