Activity › Forums › AJA Video Systems › video playback (monitor)
  • video playback (monitor)
    Posted by Sithcommander on May 22, 2005 at 6:31 pm
    I installed a Kona2 and would like to use it to monitor while editing.
    I am still editing at low-res (miniDV offlineRT codec).
    Eventually I will online 1080i, but for now my raid is still RAID 5 and I’m editing at low-res).
    What audio/video settings configuration do I need to monitor?
    I’ve already set up a RGB Sony monitor from the Kbox and can see Mac desktop, but cannot find the correct external playback/K2 control panel setup to monitor the footage at offlineRT.
    Thanks in advance.
    Jared Picune replied 21 years, 4 months ago 3 Members · 3 Replies
  • Jared Picune
    May 22, 2005 at 7:39 pm
    As far as I know the Kona 2 does NOT support offline RT monitoring. Use all of the AJA easy setups as reference to what you are able to monitor through the Kona 2. However, I think you are able to capture to offline RT through the Kona, just not view it though your monitor.
    If you are editing HD offline, and you have the space, I would recommend using the DVDCPOHD codec. You can then monitor it in actual HD or down-convert it and monitor it in SD.
    Jared
    Idea Spring Editing, Inc.
    Denver Final Cut Pro UG
  • Jerry Hofmann
    May 22, 2005 at 8:25 pm
    Not to step on Jared, but you can view DV’s offlineRT thru the kona… just set it’s output to be 29.97 NTSC. I checked this out just now, and it works…
    Jerry
  • Jared Picune
    May 23, 2005 at 3:28 pm
    Jerry,
    I was referring to the Photo-JPEG offline RT. I don’t seam to have a setup for a DV offline RT. Am I missing something?
    Jared
