Activity Forums VEGAS Pro Video Pass Through Problem
  • Video Pass Through Problem
    Posted by Liza Minge on June 23, 2008 at 1:21 am
    I have a Canon DV camera that has an analog-DV pass through. I connected the VCR to the camera, made the appropriate settings, connected the firewire to the computer, but Sony Vegas 8 doesn’t seem to recognize properly the digital signal it is receiving. I can hear the audio on the computer speakers, but the video in the Vegas capture screen shows for a few seconds and then nothing. I never get any buttons available to record. The occasionally the video pops back on but just for a second or two, but still no buttons available. I don’t have the “stop capture if frames are dropped” checked either. This is the first time I’ve tried the pass through. The video shows up fine on the camera screen, btw. Any ideas on what the problem could be?
    Liza Minge replied 18 years, 2 months ago 4 Members · 6 Replies
  • Mike Kujbida
    June 23, 2008 at 10:21 am
    VidCap (the capture utility) still thinks it’s controlling the camcorder so this feature needs to be turned off.
    Options > Prefs > General.
    Deselect the “Enable DV device control” option.
  • Allen Zagel
    June 23, 2008 at 1:30 pm
    As Mike says above, even though you’re using the camera as a pass-through device, you’re still doing an analog capture. It would be the same if you were using the Canopus/Grass Valley ADVC boxes.
    You’ll need to turn off the automatic control and do it manualy.
    Allen
    ASX Media Group, Inc.
    https://www.asxvideo.com
  • Ralph Hajik
    June 23, 2008 at 3:25 pm
    Hello Mike & Allen,
    I have Vegas Pro8 on my PC.
    I was just checking what you have stated
    I don’t see “DV device control”
    Where exactly is that located? or how is it phrased?
    Ralph Hajik
  • Mike Kujbida
    June 23, 2008 at 4:11 pm
    Ralph, this option is found in the VidCap (the capture utility) Prefs, not the Vegas Prefs.
  • Ralph Hajik
    June 23, 2008 at 6:47 pm
    Mike,
    I Got it now.
    Ralph Hajik
  • Liza Minge
    June 24, 2008 at 1:20 am
    That fixed the problem. Thanks!
