Activity › Forums › Blackmagic Design › Video Output on Decklink Multibridge Pro
  • Video Output on Decklink Multibridge Pro
    Posted by Kai Whittaker on September 14, 2006 at 2:31 pm
    Hi..
    This is actually two fairly simple questions.. I’m new to decklink multibridge pro so I’m not sure I’ve got the settings right in Final Cut Pro..
    1. My video monitor (using the NTSC composite out) plays back just fine during standard definition editing, but when i switch to an HD project, it only shows me paused frames, when I start playback, it stays stuck on the previous frame until the playback stops, then refreshes to the frame where I stopped playback. How can I get it to playback properly when I’m using an HD timeline? I tried turing off the mirror on desktop but the monitor still stays frozen on a single frame..
    2. Is there any way to get composite playback on the Y out? I have a Decklink HD Pro 4:2:2 and I can switch from component output (Y, R-Y, and B-Y) to composite output on the Y out.
    Any ideas would be much appreciated.
    Thank you!
    Kai Whittaker replied 20 years ago 1 Member · 0 Replies
  • 0 Replies
