Activity Forums Blackmagic Design Video outlipsync using Driver 5.1 on PPro
  • Video outlipsync using Driver 5.1 on PPro
    Posted by Argotmedia on August 26, 2005 at 11:28 am
    Dear Shane,
    I’ve been using Decklink Extreme with 4.6 driver on PPro, and it has worked
    seamlessly perfect, either capturing or printing to tape.
    I use the Extreme card for my subtitle project using TGA as Alpha Channel.
    With the old driver, prior to 4.8 driver, it all worked well.
    But after using 5.0 and afterward driver, i always find that upon Printing To Tape from the timeline, the video result (using PAL AVI format) is outlipsync after 9 menit. But it sometime can be corrected after trying for 2 or 3 time taping.
    Could you give a brief solution on this?
    Thanks a lot
    Regards
    Argot.
    Here is my Configuration :
    Dual Opteron 1,8
    2 Gig RAM
    Windows XP Service Pack 2
    Ppro 1.5
    Using Inscriber for producing TGA image
    4 Hard Disk SATA Raid 0
    DirectX 9c
    Windows Media Player 10
    Dear Shane,
    But after using 5.0 and afterward driver, i always find that upon Printing To Tape from the timeline, the video result (using PAL AVI format) is lipsync after 9 menit. But it sometime can be corrected after trying for 2 or 3 time.
    Thanks a lot
    Regards
    Argot.
    Dual Opteron 1,8
    2 Gig RAM
    Ppro 1.5
    DirectX 9c
    Argotmedia replied 21 years ago 3 Members · 4 Replies
  • Luke Maslen
    August 29, 2005 at 7:07 am
    Hi Argot,
    [Argotmedia] “i always find that upon Printing To Tape from the timeline, the video result (using PAL AVI format) is lipsync after 9 minutes.”
    Please review the technial note named Video increasingly lags behind audio in Premiere Pro and let me know if you think this might be the answer to your problem.
    Regards,
    Luke Maslen
    Blackmagic Design
  • Argotmedia
    September 1, 2005 at 7:39 am
    Thanks, Luke.
    I guess my 4 SATA Raid 0 is faster enough just to handle 8 bit PAL
    eventhough i use so many TGA on my project.
    Perhaps it due to my overcrowded disk, containing so many trash of deleted video files. I will try to wipe my disk first, then reinstall the 5.1 driver.
    And then I’ll let you know the result.
  • Zechariah
    September 2, 2005 at 12:36 pm
    Hi Luke
    I found this problem happened with driver up V5 if the TGA is not saved in the raid drive, by movieng TGA to raid drive it fix this problem,
    this problem never happen in the old driver
    thansk
    ZAK
  • Argotmedia
    September 5, 2005 at 4:57 am
    Dear Zak,
    How many disk you are using for your disk array? And what kind of disk interface
    yuo are using?
    I’ve loaded all the TGA on my disk array, but still it happened
    on V5 driver and later. On the earlier version it didn’t.
