Activity › Forums › Blackmagic Design › Video Ouput in FCP Doesn’t Change w/ Easy Setups
  • Video Ouput in FCP Doesn’t Change w/ Easy Setups
    Posted by Sean Oneil on June 14, 2007 at 1:28 am
    This is a problem that exists in FCP 5 and 6. I don’t know if this is a Blackmagic thing or an Apple thing.
    If I change my Easy Setup, it does not change the video output. Since upgrading to version 6 I now am using 10-bit (ProRes) projects along with 8-bit (DVCPro) and switching back and forth regularly. The fact that Video Output doesn’t change with it is rather dangerous. I garantee that me or another editor here will overlook it and unknowingly output a 10-bit project using the 8-bit video output.
    Rafael Amador replied 19 years, 3 months ago 3 Members · 2 Replies
  • Chris Borjis
    June 14, 2007 at 5:08 am
    I believe its an apple thing.
    You just have to check/change that everytime.
    I was really hoping apple would link the video output with the easy setup but its not doing that yet.
  • Rafael Amador
    June 14, 2007 at 5:44 pm
    I never had the out-put changed when changing easy set-ups. I always had to chage it manually. But in my case I can not mistake an 8b sequence being read as 10b or the opposite. My BM its only out-put a freeze frame in those cases.
    rafael
