Activity › Forums › Broadcasting › video or audio watermarking
  • Randy Pfeiffer
    January 31, 2006 at 12:26 am
    The company I work for uses Verance, Veil , Teletrax, & Sigma (nielsen)…
    Here’s what I know (or think I know 😉)
    Verance is an audio watermark (export audio for Avid, run thru encoder software, import encoded audio back into Avid and output-to-tape) – though I think they also have a “stand alone” box
    Veil encodes its’ watermark in video (uses full frame of video) encoding info on each line of alternating fields
    Teletrax uses a portion of the video (I believe it encodes its’ info in regions of high contrast, sharp lines, etc.)
    and last but not least…
    Sigma (nielsen) puts its’ info in vertical interval (lines 20 & 22)
    I’m sure there are others on the board who can add more to this thread, but I hope this gets you started
    Cheers,
    Randy
  • Mark Suszko
    February 1, 2006 at 7:56 pm
    Companies have been marking using ultra-tiny CG type way out of safe title for decades. That’s easy enough to defeat if you are looking for it, by masking or DVE-ing it out. Putting something in the close-captioned line 21 area is also done. I knew about digitally watermarking still images, but not about video, I’ll have to check those companies out.
  • Michael Brown
    February 3, 2006 at 1:32 pm
    Veil encoding degrades the picture.
    Mike Brown
    Video/Film Producer
    American Heart Association
