Activity Forums Adobe After Effects Video Only Showing a Solid Color on Import – Tried Transcoding
  • Video Only Showing a Solid Color on Import – Tried Transcoding
    Posted by David Bitterman on May 12, 2021 at 3:47 pm
    Hello,
    I have a .mov file that I’m bringing into AE, and upon import it just shows a solid green box. The preview tile shows that there is audio, however I do not hear it. The issue is no video frames, just a solid color. I went into media encoder and bounced it out as an MP4 and am still getting the same issue. Please help!
    Walter Soyka replied 5 years, 4 months ago 6 Members · 6 Replies
  • Kevin Reiner
    May 12, 2021 at 3:57 pm
    I fear you have a corrupt file. Do you have access to a more original source file. Hopefully still on camera. How long is the clip supposed to be and how big is the data?
  • Chris Voelz
    May 12, 2021 at 6:07 pm
    Try changing the “Video Rendering and Effects” from Cuda to OpenCL to Software and see if making that change helps. I had a similar issue in Media Encoder once, might help here too.
  • Eric Santiago
    May 12, 2021 at 6:36 pm
    And always check another viewing option.
    PPr, VLC, AME, QT, WMP, etc…
  • Kevin Camp
    May 12, 2021 at 6:53 pm
    And if you do transcode, don’t transcode with another Adobe app. I’ve found when AE has issues with a file, AME often does too.
  • Eric Santiago
    May 13, 2021 at 2:32 pm
    This is where the free version of Resolve helps.
    For some, it’s required.
    I have four NLEs on most of my systems and boy you can sure waste a lot of time tinkering with bad codecs 😛
  • Walter Soyka
    May 14, 2021 at 1:50 am
    I’ve been using Shuttle Encoder a bit lately — it’s a great frontend for the open-source ffmpeg tool:
    https://www.shutterencoder.com/en/
