Activity › Forums › Avid Media Composer › Video on Premiere is good, but on Avid it’s darker and unsharp – how can i solve it?
Posted by Ploom Pi on December 5, 2016 at 10:11 pmI used the same video on Avid Media Composer 8.4.5 and Adobe Premiere Pro CC 2017.
The video looks sharp and clear on Premiere but dark and unsharp on Avid. Does anyone knows how can that be solved?
thank you.
Santiago Escudero replied 9 years, 7 months ago 6 Members · 12 Replies -
Shane Ross
December 6, 2016 at 1:34 amNot sure about Premiere…but the Avid interface…the SOURCE and RECORD monitors…aren’t accurate. They aren’t designed to be. They are there to allow you to see what you are doing. Do not judge the quality of the image on those monitors…only an external one connected via an IO device.
That being said, is your sequence half/yellow half/green in the lower left? Click on it to make it full green. That’s the QUALITY setting.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Ploom Pi
December 6, 2016 at 12:41 pmThank you for your answer, yes, i’ve done all you said and the problem is not only on moniter but also on the outcome video on different monitors, i’m having hard time to find what am i missing in order to get a white as a perfect white ☹
Shane Ross
December 6, 2016 at 5:13 pmWhat are you rendering to out of the apps? meaning, are you exporting a DNxHD Quicktime? Or H.264? H.264 DIRECTLY out of Avid isn’t good. Avid is bad at making a good quality H.264 directly. So you need to export a DNxHD file, and encode that with a third party encoder, like Media encoder, or Compressor or Squeeze
Shane
Little Frog Post
Chris Wright
December 6, 2016 at 8:39 pmadobe media encoder has configure settings for dnxhd for RGB or video levels. that is most likely your issue. 0-255 vs 16-235.
Ploom Pi
December 6, 2016 at 9:55 pmThe export is Quicktime movie > mov > same as source, i don’t know how to export in another way, or how to export DNxHD – i don’t see this kind of option :\ but the color is not right even before exporting, so i’m not sure that’s the issue. I think it has something to do with color levels 16-235, like the 0-16 is missing… just can’t figure out where my settings are wrong, as i’m not a big colors and numbers guy.
Ploom Pi
December 6, 2016 at 9:57 pmChris Wright – i didn’t get what do you mean, as avid is not adobe’s… and after encoding in the media encoder – the problem isn’t solved, or tell me what to choose on the encdoer… thank you.
Chris Wright
December 7, 2016 at 1:34 am“color is not right even before exporting”
are you editing in avid and then exporting a full render or XML? how can the color be wrong in avid if you’re color correcting in avid?
What is your workflow? -
Ploom Pi
December 8, 2016 at 1:29 pmI’m sorry for confusing you all, i think my import was wrong, or maybe i shouldn’t import at all and just use link ama? I’m used to an old way of editing which might be wrong, so trying to figure things out…
I used to import all videos as dnxhd 45 and in the end batch import them all to MXF 1:1 on a previous Avid 5 version i had on my old PC (Win 7 32bit),that was my best settings back then, but now with my new PC (Win 10 64bit) and new Avid version, it seems wrong or maybe i’m doing all the import and stuff in the wrong way.
What would be the best settings?
I’m working on mov and mp4 files in h264 codec, usually HD 1080p.thanks.
Glenn Sakatch
December 8, 2016 at 7:51 pmAvid is probably interpreting the footage wrong during your import.
Go to your import options, and change the switch that says “keep legal” or “change to full range”
How ever you have it set is probably wrong.Glenn
Adam Nielsen
December 10, 2016 at 1:56 amBest not “import” footage ever in avid. You want to link to ama and transcode footage to desired resolution. DNx145 for 59.94 1920×1080 footage and DNx115 for 23.98 1920×1080.
