Activity Forums Adobe Audition video not running smoothly
  • video not running smoothly
    Posted by Rinforzando on April 19, 2007 at 12:42 pm
    I’m trying to sync 30 min of dialog to a wmv video that is about 500mb in size. I have a machine that should have no problem in running the video, it has a Athlon 64 5200+ cpu, Abit kn9 sli motherboard, a Radeon x 1950 series video card and 2 gig of ram. When playing the video from the beginning everything runs ok but when i try to jump to each point of speech and repeat the sequence it either freezes or runs out of sync. Ive tried audition 2 but that wont even run the clip so ive gone back to 1.5. Is there anyway to increase the video cache??
    Thanks for your help in advance
    Kind Regards
    Matt
    Darren Edwards replied 19 years, 4 months ago 2 Members · 1 Reply
  • Darren Edwards
    May 9, 2007 at 12:23 pm
    I think the answer to this is really complex, because I’ve
    been following all the ‘optimal settings for cache’ advice
    for years, from people here, at Adobe (forums), and from
    Syntrillium, but unfortunately, my Audition still isn’t rock
    solid when it comes to video in the multitracker.
    Regardless of file size, or my PC’s power, almost every sync
    session will start to lag after an hour or so. You could try
    reducing the video quality to ‘low’ but I haven’t found it
    made much overall difference. If it’s not working at all in
    2.0, you need to make a few noises about it at the Adode Forums.
    Good luck,
    Darren.
    x-gf.com
